Burlapen
Curious for those that are, what harness and engine management are you using? Stock stuff? Mega squirt? How much power are you making? I did the carb deal originally but considering tossing the stock efi on.
On my '68, I'm using the factory ECM originally for a 1998 3/4 ton truck w manual trans, Hotwire Auto's Hot Rod Harness(4 wire hook up), Ford 40lbs racing injectors, a mildly ported Airgap intake with Massaged Eddie heads & a Hughes Engine's Big Gulp throttle body. The hydraulic roller cam is ground with a 108* LSA and just over 250* @ .050 duration.
The ECM was reflashed to correct the fuel and spark tables for my application. The car chassis dyno'd at 382 hp @ 4580 rpm & 525 ft lbs of torque at 3541 rpm at the rear wheels. This is through full exhaust including aftermarket metal matrix racing cats.
It gets around 14 mpg around town and 17 mpg at 70 mph on the freeway. It does have an overdrive trans & lock-up converter, but I only use that on the freeway.
The stock OBD2 ECM can be reprogrammed suitably for most applications the factory Magnum block will hold up to, even boosted applications. I am not sure how long SCT will continue selling the programmers, but right now you can still get one and several shops still offer canned tunes for common setups and custom tunes as well.
The harness is no big deal. Use a factory harness, keep what you need, cut out the wires you don't need. If you are not really comfortable with wiring, get the fuse block that the engine harness plugs into from the donor vehicle and just leave the extra wires in place.
Compartment looks fantastic! Where did you place the computer and PDC? Curious if you relocated under dash? Like the look and starting a swap now.On my '68, I'm using the factory ECM originally for a 1998 3/4 ton truck w manual trans, Hotwire Auto's Hot Rod Harness(4 wire hook up), Ford 40lbs racing injectors, a mildly ported Airgap intake with Massaged Eddie heads & a Hughes Engine's Big Gulp throttle body. The hydraulic roller cam is ground with a 108* LSA and just over 250* @ .050 duration.
