NWDave
My 318 2 barrel engine is supposed to be rebuilt, to stock specs. I have started gathering some speed parts, in hopes of gaining a little more performance out of it. If I do a compression test, how much PSI should I expect? I want to tear into the engine, and do a cam/lifter/valve spring swap, and top it off with an Edelbrock Performer manifold, and Performer 600 cfm carb.
