cavemanmoron said:8.8? Why not a 9 inch, parts are easier to find.
What did it come out of, does it bolt right in an abody?
At least being Ford, the bolt pattern is ok.
I would bet an 8.25 from a 1973-76 abody would be an easier swap.
How much power does your engine make, or are you planning on?
66dartman said:The late model mustang boys use that rear and there are parts to eliminate the c clip axles. The tubes have been known to spin in the third member. The only advantage is that they are available and cheaper than an 8-3/4, but 350 hp is about all you would want to push through a stock one, even that is on the edge.
