My car has ran a best of 11.78 @ 118 in track trim. On the dyno in street trim it made 284 hp @ 5250 and 305 ftLB @ 4687. Street trim = remove electric water pump drive and electric fan, install clutch fan and shroud, add 2 1/2 tail pipes to the 3 H pipe and mufflers, replace race clutch with street clutch, change rear end gears to 3.91s from 5.13s, Stock air cleaner, move battery from trunk to under the hood. My car is 3100 lbs.
I think my dyno numbers are low, but I know what the car runs so what the hell, its only a number.
