Not sure if this is the right forum or if BB would be better. The question is how much oil do you run in your big blocks with a 7qt milodon pan. I seem to have a lot of crank case pressure. 500ci on a 400 block. and yes I do have a evac kit on it. I've been fighting oil leaks on the motor. fix on and get another.
