RockinRobin
Thinking about switching to fiberglass hood this winter. What is the easiest way to secure it to the car? Dzus? Hood pins? Looking for no weld installation.
Easiest is pin it, Dzus a bit more planning & weldingThinking about switching to fiberglass hood this winter. What is the easiest way to secure it to the car? Dzus? Hood pins? Looking for no weld installation.
If your fiberglass hood is more “robust” we got away with four pins at the corners, which simply required drilling holes. I later went to a lightweight race hood (1/2 the weight of the old one) and have 8 points of attachment with that one. That deal required welding some tabs for the additional mounting points. Originally on the lightweight hood we ran Quik Latches which were great looking, but a pita to set up and align. I just recently chit canned them and now have ugly pins again…. but its so much easier!
I use pins on mine. I can easily place hood or remove by myself.Thinking about switching to fiberglass hood this winter. What is the easiest way to secure it to the car? Dzus? Hood pins? Looking for no weld installation.
Agreed, I likely should have mentioned mine is a dedicated track car, thus the pins.Why not use a bolt on?
Pin on hoods on anything other than a race car with a pin on nose as well never made any sense to me, but neither does life since 2020, so......
Agree ,^^^^^^^^^^^^^^ especially in narrow garage , where to put it is a pain ,especially in a narrow garage ,16x38 .Why not use a bolt on?
I broke the hood hinges about 2 months ago, So I've been racing with no hood, which weighed about 75 lbs. It might be coincidence, but E.T. picked up significantly. Might be weight, might be breathing better, might be both, don't really know. There's gotta be some wind drag though with no hood.Why not use a bolt on?
Did you figure out who you're going to buy from ?I broke the hood hinges about 2 months ago, So I've been racing with no hood, which weighed about 75 lbs. It might be coincidence, but E.T. picked up significantly. Might be weight, might be breathing better, might be both, don't really know. There's gotta be some wind drag though with no hood.
Not yet. Best price I can find is Glory Days Fiberglass.Did you figure out who you're going to buy from ?
Where are they ?Not yet. Best price I can find is Glory Days Fiberglass.
The claim has always been (at least that's the way I heard it) a tenth for a hundred pounds. So theoretically, you should have picked up . 075. More than that, maybe due to more cold air. Less than that, maybe look at your mph, drag from not having a hood might show up there.I broke the hood hinges about 2 months ago, So I've been racing with no hood, which weighed about 75 lbs. It might be coincidence, but E.T. picked up significantly. Might be weight, might be breathing better, might be both, don't really know. There's gotta be some wind drag though with no hood.
McAlisterville Pa. About 30 miles NW of Harrisburgh.Where are they ?
