lilredridinghoo
tried the forums search - but didn´t really find an answer....
how to detect a worn torque converter ?
i´m asking cause of my daily drive 1970 valiant 318 stock engine with TF904 trans.
maybe i´m a little bit neurotic, but the car does not downshift and accelerate as before - if i push the pedal at 55 mph nothing, at 50 mph sometimes if shifts down, at 40 or 35 mph it shifts but if feels not powerful
first thing i checked was the kickdown-linkage - but everything is fine with it.
so i thought about the converter or cld it be somewhat else... how to check a converter for proper function ?
cld. it caused by a cloged air-filter (indeed it is very polluted, and should be replaced)
also i´d changed the point-breaker-style distr. thing to a pertronix-modul (but didn´t have the chance to check the timing since)
i also have serious vibrations i cld. not really locate for more than a year... there noticable when the car rolls along the streets in the city at 30 mph (1400rpm or so) and no force on the pedal, only when its slightly touched. if i rev up only 100 rpm its over and will be come back 2600 rpm on the highway. i can feel them in the steering wheel and on my butt sitting on the bench.
