Sirsmiley9
Im looking at Brewer's performance and in order to rebuild the very loose shifter, but I dont know how to tell the difference between the two types of shifters.
Picture?Im looking at Brewer's performance and in order to rebuild the very loose shifter, but I dont know how to tell the difference between the two types of shifters.
unfortunately I dont have the car with me right now so in the next week I should be able to check and order it
Would that tighten up the shifter itself at the moment it has a lot of play in each gear, and when you say get a hurst shifter do you mean get the entire assembly I know that on the arm itself it says hurst.I had another thought. I might be an ITM or Inland shifter. Don't bother trying to fix it, get a Hurst shifter. First start by torquing the handle bolts, if it has them. Next, torque the shifter mounting bolts, 9/16 and 5/8. Get shifter clip and washer package, Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists , Some O/D A833's had hairpin clips. Next clean, blue loctite, and torque the shift arms to the transmission. I use grade 8 washers and nuts. Use the alignment tool and adjust the linkage rods for Neutral. Only then go into the shifter if that does not tighten it up.
