downsr
What is the procedure for finding tdc using piston stop. Need to make sure my balancer is correct on small block
Disconnect battery for safety. Insert the device in no1 making sure the piston is down. The length of the plunger is unimportant, but you want the piston to stop "down a ways." If you buy one rather than building one, make sure you get a lock nut on there to stop the stem from wobbling around
CAREFULLY wrench the engine around until the piston stops on the device. make a temp mark under TDC on your pointer tab, onto the balancer
Rotate the engine opposite direction do same thing. This will result in two temporary marks, and halfway between is TDC
If the original mark is correct, that is where it will be. This is one I built for SB Mopars in the '70s. Had it all these years
bring dampener to 15 BTDC. screw in piston stop till it contact the piston. turn crank back CCW till it stops again. you want it to stop on 15 ATDC. go back/forth 1 time to double check. if it stops on 13 then make a new white paint mark (1) degree on the side of the OE slit (I forget which side). repeat the test. You want the same degrees on each side. EDIT (1) degree is 0.0632683" or use the dampener as a ruler.What is the procedure for finding tdc using piston stop. Need to make sure my balancer is correct on small block
In what way bro?Good Goawad that is AFU
In what way bro?
I've done it before that way & it checked out fine. tell me how it would be erroneousIn every way known to mankind. That was the most jumbled up bunch of hooha I ever read.
"A jumbled up bunch of hooha" and "AFU" ain't saying it is wrong? you sure coulda fooled me! yes you would need a degree wheel to degree the cam & be careful that it dont move as you are turning the crank & other caveats but just to find true TDC to confirm the dampener ain't slipped I don't see a problem with the simplicity of this & it don't see more difficult than using the wheel. I'm still trying to figure out which one of you is the one who gave me the uncalled for scathing rebuke way back for no reason when I first got on here (I gotta get my printer going). a fellow member saw it & emailed & said that you were a former naval chief or something similar & that "they are like that". I thought yeah right but I thanked him for the backup/support. RobertI didnt say it was wrong. But, it;s a pretty confusing way for someone who is not familiar with finding TDC.
It sounded personal. Alright, My apologies brother. I thought it was a simple procedure but that could just be me. Yes you're right on the "2nd time" statement, wont happen again & it was the other guy, this guy "67dart273". I wished I woulda saved it, it was something else! & on the procedure I'm trying to remember which way (side) you remark the slit if it comes up more or less than 15 when you come back CCW to try & hit 15 ATDC.Have no idea about that. That's the second time you've said that and this is the second time I have told you I have never served.
Sorry you can't take a little criticism, but that was a very confusing post. It was nothing personal.
Early A's had a bolt on pointer that tends to disappear after the first water pump housing removal. without it or with a different year/aftermarket balancer, you got no idea where TDC is hence the temporary pointer.
So I all I have to do is turn # 1 up on compression stroke to 10 degrees before tdc on my balancer turn in the stop till it hits the piston .Rotate the engine in opposite direction till it hits the stop. Make a mark. Then find the center between the 2 marks
I agree. with you getting 8 & 10 degrees then yes the dampener is 1 deg off (fairly common) but do confirm everything is rock solid. I've been racking my brain to figure out which side of the OE slit that (1) deg next to it is true TDC but I ain't grasping it (yet). & I will concede that if you are going further & degreeing the cam (always a good plan) then the wheel is a good plan.MAKE SURE the plunger is RIGID.
