d1970
TODAY IS A GOOD DAY TO HAVE A GOOD DAY
I have a friend that needs help with his voltage limiter on his 1968 Ralley Gauge cluster. I know the voltage limiter is part of his gas gauge, but how do you fix it. Thanks
Solid state voltage limiters are available on Ebay. They go for about $50.00. Homemade solid state VL can be made from Radio Shack parts for about $3.50 and an hours time.
Plenty of information available on the FABO, FBBO, and FMJO forums if you search for it. There is no real fix to a bad one. You can take them apart and clean the contacts but, I've not seen that last very long.
the 68 Ralley Dash cluster does not use the plugin VL, it's built in the gas gauge.
I'm not sure anyone is claiming that. If you read the info posted on the RTE page it shows how to "jumper in" an external limiter for the internal fuel gauge unit
We all know that method shown is sketchy at best. Would you do it? Your opinion matters. The IVR they sell works great but!
Well, what's your alternative, for keeping original-looking gauges? We don't all want some crazy tuner-looking dashboard.
I bought one for each early A for $30 on ebay. Seller was PinkPatty or such. Search "voltage limiter" w/ "Plymouth" to fin. The output voltage is adjustable, which helps in getting your fuel gage scaled correctly. It comes in a plastic case w/ wires, not the later silver "factory can" of the RTE shown. Since I hate mutilating factory parts, instead of bending the bi-metallic leaf inside the fuel gage, I just slipped heat shrink over to disable it.Solid state voltage limiters are available on Ebay. They go for about $50.00. ...
Yeh, I WOULD. Several people warn about the delicate surgery, but seems like all you need to do is be methodical and careful, and test as you go along.
