How to pick an electric fan?
moparmade43
I am needing some help in deciding how to size and select the proper electric fan for a street car. Does anyone have any expertise in this area, or know of any good articles to find the required cfm that is needed? I am not having much luck. My car is a 75 duster, 416 stroker, eddy heads and air gap intake, tti headers, northern aluminum radiator, standard water pump. The radiator measures 20.5 inches wide, 17 inches tall, and no more than 3 inches from radiator to water pump pulley. I need a puller, as I have my transmission cooler mounted on the front of the radiator. Any help would be GREATLY appreciated.
Thanks,
Will
:toothy10:northern makes a fan shroud setup to fit there rads and they work great, got mine from fbo or 4secondsflat, best prices i could find and supernice guy,good luck, also have milodon highflow water pump and high flow thermastat
