Ron816
Mopar forever
How should I approach repairing this gap?
everything is shimmed the fender is as far back as it can goMake sure the door is aligned properly to the quarter first
. Then work on shimming the fender accordingly.
the body lines at the rear quarter and the rear part of the door are spot on if I lift the rear of the door to tighten up the gap the rear of the door will be much too high I need to fill the gap somehow, possibly with welding rod?If the red is the door, I'd start by shimming the bottom hinge or rebuilding the hinge itself. If the lower pin is wallowing in a ratted out hinge, no shimming is going to correct it.
yes its a AMD fenderIs the black a repop fender? I bought a new repop fender for a Subaru GL-10 and it fit like that. Nothing I could do to get it any better. It was just made wrong.
I'll probably cut the fender and re alignyes its a AMD fender
end of story. heard alot of bad on amd fitmentyes its a AMD fender
LETS COME BACK TO THIS EXCELLENT SUGGESTION. Assuming the door is OK, align it to the quarter panel and rocker panel. This is ALWAYS the way you reassemble and align everything. The doors have to be fitting against the quarter panel and rocker first. Then align the fenders. You may still have to tweak the doors a tiny bit, but if they are nicely aligned against the quarter panel and rocker, you are 90% there. If the door is properly aligned and you still have that gap, it is time to 'make' it fit. You will be doing some cutting and welding. You might even be able to fix the gap by adding a bit to the door. Either way, it should not take too long. It's hard to tell without seeing it.Make sure the door is aligned properly to the quarter first
