pinkiedog64
Member
Hello! I am new member here. I have just picked up a '60 4 door Valiant. It has been sitting in the same spot outside in TX for the last 36 years. It's a 170 with a 904 push button. 'Tis going to be a project...
I am an active member on the slantsix.org and sweptline.org forums. I have a '64 D100 with a freshly built up slant. Got a 383 B to stroke, turbocharge and install in the truck. Slant in the truck is coming out, getting different cam, pistons, and rods, turbocharge, and installing in the Valiant one I get the other systems working. I am currently in the process of replacing the brake system on the car. I am looking for the following parts for it: radiator, driver side rear triangle glass, 60-62 manual trans pedal assembly for an 833 OD swap, and a driver door vent glass outer hinge.
Here are a few pictures:
Looking forward to getting to know y'all and get some good information and help!
Stephan Nelle
Stephan Nelle
