1. rigger3006
    rigger3006 Well-Known Member
    786
    204
    Aug 6, 2013
    bc
    Local Time:
    3:31 AM
    ive had this t/c for a few years now, ive had a few rough idle cams in front of it, i could idle engine down to 4 to 500, throw it in gear and tach wouldnt even move. got it going this spring and now idle drops 2 to 300 rpm, even stalls out like low stall factory t/c i had before.question is, can i ''lose my stall''? or am i missing something?
  2. CudaFactHackJob
    CudaFactHackJob FABO Gold Member FABO Gold Member
    1,651
    623
    Mar 17, 2016
    Hemet, Ca.
    Local Time:
    3:31 AM
    Are you running a four cylinder tach??
  3. rigger3006
    786
    204
    Aug 6, 2013
    bc
    Local Time:
    3:31 AM
    no, same tach for last seven years, although i have switched from holley to a thermoquad?
  4. CudaFactHackJob
    1,651
    623
    Mar 17, 2016
    Hemet, Ca.
    Local Time:
    3:31 AM
    J/k..but are you running the same valve body?
  5. rigger3006
    786
    204
    Aug 6, 2013
    bc
    Local Time:
    3:31 AM
    nothings changed except carb, i guess i could put holley back on and see what happens, just spent good money on the tq though
  6. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    20,774
    8155
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    3:31 AM
    faulty low-speed circuit and or incorrect transferslot exposure
    You said;
    But since you failed to mention this, in post #1,
    I gotta ask;
    did you change the timing?
  7. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    19,118
    6324
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    3:31 AM
    I had a lot of TQs in my day but never really used them on cammed up engines. They didn’t like to idle very well. Put them on something stock and they ran fantastic. Kim
    • Like Like x 1
    • rigger3006
      786
      204
      Aug 6, 2013
      bc
      Local Time:
      3:31 AM
      timings the same, idle is all over the place, no vacuum leak, this is the 2nd tq ive tried with lumpy cams, going back to holley tomorrow and see whats what
    • oldkimmer
      19,118
      6324
      Nov 11, 2006
      Local Time:
      3:31 AM
      They can be made to work very well with bigger cams but I didn’t have the patience. Kim
    • AJ/FormS
      20,774
      8155
      Jan 19, 2014
      Local Time:
      3:31 AM
      At what camsize would you suggest a switch? Ima thinking more than 230@.050 or less than 10inches of idle vacuum.
      Your thoughts?
    • oldkimmer
      19,118
      6324
      Nov 11, 2006
      Local Time:
      3:31 AM
      Mine didn’t like much cam over stock. But I never really played with them as I had lots of AVS and AFB carbs. Kim
      • Thanks! Thanks! x 1
      • rigger3006
        786
        204
        Aug 6, 2013
        bc
        Local Time:
        3:31 AM
        put the 750 holley back on with hvh super sucker under it on holley street dominator intake, runs like a sumbitch,need to tune out a bit of bog.now to sell tq 9810s with electric choke
      • rumblefish360
        rumblefish360 So close, yet so far away FABO Gold Member
        40,728
        12261
        Jun 21, 2005
        New York, on a Island
        Local Time:
        4:31 AM
        That was weird....
      • fishmens67
        fishmens67 Well-Known Member
        9,912
        8443
        Nov 10, 2012
        idaho
        Local Time:
        3:31 AM
        Why would anyone change from a good running Holley to a TQ.
        Tuning a Carter is not for your average shade tree mechanic. lol
        • Agree Agree x 1
        • oldkimmer
          19,118
          6324
          Nov 11, 2006
          Local Time:
          3:31 AM
          Especially a TQ. Kim
        • rigger3006
          786
          204
          Aug 6, 2013
          bc
          Local Time:
          3:31 AM
          boredom, trying something different, i like spending money i don't have.....etc,etc.... what can i say!
