BB4-speed
Member
Has anyone used the whiplash 360 cam? It is not recommended for stock magnum compression (to much psi ?) with 108 lobe sep. 110 lobe sep recommended for stock comp. ratio. I am building a budget 360 mag stock bottom end rebuilt moly rings new rod bolts ported & massaged EQ heads M1 single plane 750 dp holley for my 67 cuda fb 4-speed.Just wondering if any of you guys have experience with Hughes 360 mag cams? THANK YOU
