Dustert73
Stripping bolts since ‘10
I have a hurst shift mechanism and stick I won't be needing. From the research I've done on mechanism numbers it's intended for '68-'69 B Body, '68-up A body and '76-'80 F-body. It's has 25561 stamped on the body, and 6353 stamped on the long arm which I believe to be the reverse lever. 90$ shipped in the lower 48
The stick is a hurst 4078 replacement stick. Intended for use in all 1962 to 1970 B-body non console applications. (Sorry it's not an a body part) For use with bolt-on style Hurst shifter mechanisms. 3/8"-16 thread. It has some minor rust pitting and a few scratches, see pics. 75$ shipped in the lower 48
