Hurst Competition 4 speed shifter
ZooKypr
NJ
Looking into swapping out from my '66 Barracuda Formula S my original Inland shifter for Hurst Competition 4 speed shifter for better performance. Any idea on part numbers or pricing. Everything I've seen so far is for 1967 n up A-bodies & B-bodies. Any insight is appreciated.
:blob:
any hurst comp plus A-body shifter will work, they are all the same
let me know if you want to sell or trade your inland shifter
I am looking for an original one for my 66
I have an early 70's factory A-body hurst shifter that needs to be rebuilt for trade
the difference between an A-body B-body E- body or even a van or pickup hurst shifter is in the shape of the handle and the length of the shift rods,
so there is a high degree of interchangeability between shifters
the main difference between a standard factory hurst shifter and a comp plus is that the comp plus uses bushings that fit between the shifter and the shift rods, and the stock type shifter does not
http://www.brewersperformance.com/proddetail.asp?prod=H0001
http://www.brewersperformance.com/proddetail.asp?prod=SP68A
