Hurst Quarter stick install questions
Transmission and Drivetrain Tech
  1. niceolddart
    niceolddart Well-Known Member
    182
    63
    Dec 19, 2014
    S.E. Pa.
    Local Time:
    10:29 PM
    Has anyone installed a Hurst Quarter Stick in a 1st gen. V8 Dakota? I bought a used one cheap, with the cable, cover & all but the bracket & lever to hook it to the transmission (518/46RH) I am going to get the bracket & shift lever new from Hurst, but I have no adjustment instructions. Any help would be great. Shifter works great by the way. Thanks
  2. 89on35s
    89on35s Inferno Red Duster FABO Gold Member
    1,744
    1718
    May 11, 2006
    Martensville Sask. Can.
    Local Time:
    8:29 PM
    I have one in my Duster with an A-500 trans. I adjuster the cable so the trans and shifter are both in neutral at the same time. The rest of the positions will then line up. OD and LU are controlled separately from the shifter as you likely know.
    Cley
  3. niceolddart
    182
    63
    Dec 19, 2014
    S.E. Pa.
    Local Time:
    10:29 PM
    Thanks for the info Clay. I like the hood scoop on the Duster. I want to bolt one on my Dakota (a Dart sport one) some day, but they are kind of pricy even for a slightly damaged one. I'll find one eventually & make if a functional piece.
    • Like Like x 1
    • niceolddart
      182
      63
      Dec 19, 2014
      S.E. Pa.
      Local Time:
      10:29 PM
      Sorry, I spelled your name with an "A" not an "E"
    • 89on35s
      1,744
      1718
      May 11, 2006
      Local Time:
      8:29 PM
      No sweat! I get that all the time!
      Cley
