[WANTED] hurst ramrod bracket for a body
If you weren't aware the ramrod shifter isn't quite a bolt in replacement for the A body even with all the correct Hurst A body installation parts.
It does work but cutting is required. The straight rods that are a big part of why they work well are the reason for the need for cutting.
If you were determined to use the ramrod and wanted your car to remain uncut you will have to make your own mounting bracket and rods.
can I get a pic of that mounting bracket. I had a mr g ram in the car before, they take up much more room than the hurst unit. like you. SERIOUS tunnel mods are required.been there, done that.
This is the best I can post without removing shifter from transmission. I am in the middle of a move and
Its not a good time for me to be taking the thing apart. These pictures may be able to get you there.
You can probably create a better fit than Hurst did.
It consist of a transmission mounting plate with 3 spacers.
The rods and levers shown are a spare set. I believe the spare bracket has been packed away and moved already.
If nobody else post one up by the first of the month
I will have more time then to get better pictures.
they are very helpful. thank you for taking the time. I am grateful..
BINGO....scored a complete unit.cant believe my good luck.i feel like I just found the holy grail...lol...
You did. It is very rare to find a complete Ram Rod. I hope you got a good deal as well.
yup...under 250. now if I can have the same luck with the boot. I can be a happy camper...
