Hurst Shifter Mechanism Tear Down
jonn6464
1970 Duster
Weatherford, TX
Hey FABO, hoping you can provide some guidance.
I'm dis-assembling my Hurst shifter mechanism to clean and re-grease it. Will also be changing from a push in to bolt on.
Got it down to the final stage, but need help to understand how to remove the last piece. I can see 2 roll pins, and have gently tried to tap them out, but there is no movement. I don't wanna hammer on them, so they won't get damaged. Also, I see 2 springs inside. What is the secret?
Not sure but I believe those may be pressed into blind holes on that shaft. See if you can run a smaller wire all the way through the hole.
not that I recommend gas to clean with…….
