player1up
Anyone out there with a stock 3 arm clutch and a hydraulic setup, Did you remove your over center spring?
I've got a stock /6 with a 10" clutch and a hydraulic setup and the pedal is a little too easy. If I release it fast it's not a problem but in stop and go traffic where I have to let off easy it like gets "stuck" about middle of the way thu the travel. I have 2 fairly beefy return springs at the clutch fork but I was wondering if removing the over center spring would help. I've also rebuilt the pedal setup before I installed it and it's nice and smooth ( doesn't catch or bind )
OR should I get a HUGE return spring for the clutch?
Thanks
Matt
Thanks
Matt
