Hydraulic bearing clearance issues and workarounds?
Manual Transmission & Clutch Discussions
  1. tanis4457
    tanis4457 Well-Known Member
    360
    101
    Apr 22, 2015
    Mountlake Terrace, WA
    Local Time:
    12:03 AM
    My pressure plate fingers to the outside of my lakewood scattershield is 3.882". I'm using a A833OD transmission with the 308 bearing retainer that is 4.807" in diameter since that is the opening size of my scattershield. I measured 3.032" from the hydraulic bearing face to the face of the transmission. The difference is 0.849" so for my clearance to be in the spec of .150-.200" I need to use approx a .700" spacer. Now this puts the hydraulic bearing past the end of the bearing retainer shaft. Does someone make bearing retainers with longer than stock shaft lengths? Thanks in advance.
  2. tanis4457
    360
    101
    Apr 22, 2015
    Local Time:
    12:03 AM
    Nevermind got it figured out please delete this thread
  3. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    49,693
    18008
    Oct 14, 2010
    Idaho
    Local Time:
    12:03 AM
    Oh come ON some of the rest would like to know too!
  4. pishta
    pishta I know I'm right....
    20,414
    9685
    Oct 13, 2004
    Tustin, CA
    Local Time:
    12:03 AM
    that's how we learn..from your mistakes! :icon_fU:
  5. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    21,253
    8515
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    2:03 AM
    Com'on fess up!
  6. tanis4457
    360
    101
    Apr 22, 2015
    Local Time:
    12:03 AM
    I have a ram hydraulic bearing setup which has different instructions than say american powertrain, I glossed over the instructions as I'd already watched videos on how to the measurement. Well since the Ram method is different my numbers were off, I still have to call them on Monday and ask if I can just measure from the diaphram fingers to the scattershield block saver since I already have the flywheel/clutch/pressure plate mounted and I don't want to remove it to measure from the crank flange to the block per this diagram.
    https://storage.googleapis.com/ssm-ramprod/2019/12/b1002-1a_worksheet.pdf
  7. 67Dart273
    49,693
    18008
    Oct 14, 2010
    Idaho
    Local Time:
    12:03 AM
    Geez that worksheet reminds me of an IRS tax form!!! What do you think of this setup compared to some others?
  8. tanis4457
    360
    101
    Apr 22, 2015
    Local Time:
    12:03 AM
    I’m not sure it’s going to work with my setup the ram bearing seems nice. I think I’m going to try setting up one of the speedway pull slave cylinders off of the shift fork and see how that works.
