There was never a roller cam from the factory in a big block. You would need an aftermarket roller conversion kit.
Now that is cool ^^. I do know that my factory roller cam LA 318 has stamped steel rockers....So It may be possible with a big block. IF you do this, please keep us informed.
I think it was 1963 the dragmaster dart rail won the winternationals.
They used a 383 with a 413 crank 63 style max wedge heads and a identical
set of rocker arms as Jim pictured. Not sure what type camshaft they used.
Since they were out of So.Cal, did your dad by chance help them? I was at
the then Palmdale International Raceway and your Dad tuning a friend of
mines 1958 Ply Golden Commander it was running pretty respectable times.
it has been 24 hours, tell us why no go with retro hydraulic rollers, please, thank you.
LOL indeed... show us pics of broken parts that would be sweeeet!
hydraulic roller lifters do not need adjustable rockers, just the correct length pushrods. if done correctly, what parts will break ?
We could do it effectively, but, I have no intention of ever running a hydraulic roller in anything but a mild rebuild of the magnum small block. Eventually I will explain why. It has nothing to do with the rockers, but the retro-fit hydraulic roller concept.
