OK 2 Darts, what have you got there?
When I went to NAPA to get a upper radiator hose I was told that there wasn't one available, so I go in the back room to look over the available hoses hanging on the wall, trying to find one that makes the right kind of bends to meet my needs. I asked the counter man to see if there was one listed for a later model Dart with \6 and he tells me that is just a 90. I had in my mind the bend that I needed and found one that looked right, and when I got home sure enough it fit just fine. Later that evening I decided to go look at 3 other \6 motors that I have in parts cars and they all have the neck on the block directly across from the neck in the radiator, but the block neck on my 63 dart is about one inch to the left of the neck on the radiator. I have clocked the studs in the motor mounts as far to the pass side of car as I can. Any thoughts on this?
