I don't know what this tranny is.
chessman90
Member
I am trying to figure out what this transmission is. These are all the numbers i have for it.
78408172
PP833578
c15406
76-77
A991262
c13303G
4-17-77
The main case is Aluminum and the tail shaft is cast iron.
Bearing diameter= 3.544
Bearing Retainer=4.795 Part number=G13157
The arms on the transmission for 1/2 are upward and the arms on 3/4 are also upward.
The transmission functioned fined while in the car and 4th gear seamed like the highest gear. I was told the guts of the transmssion are from a cast iron A-833 and the housing of an overdrive unit. With the overdrive gear.
Thanks for any help.
If the levers are the same direction then it doesn't sound like it has OD gears in it.
Chuck
