I have forgotten how to remove these headers.
Demon499
Bartesville Oklahoma
I have forgotten of these headers on how to remove them from the car. I had put the into here but I have no clue now.
Any information will help.
Thanks in advanced.........Ted
Don't know exactly about your car, but with the 4 big block A bodies that I built, (only 1 with fenderwell headers) I pull the steering column to get more room. That's just my preference. Good Luck!
I see you have a motor plate also. I think if you raise the engine and pull the column you should be clear. I have TTI 2” on my notch with motor plate
Didnt see they were fenderwell, the master might be in the way too
Don't know about a big block, or a later A, but when I had fender-well headers in my 65 Barracuda, all I had to do was unbolt them from the heads and from the exhaust pipes and lift them out. (Maybe remove the M/C, can't remember.) Easiest headers to remove ever.
It really depends on how much clearance you have on your inner fender cuts around the tubes. When my car still had inner fenders, I was able to unbolt the fenderwell headers, and lift them out. I had to twist them while lifting up to allow the contours of the tubes get through the fender holes. My car had pretty generous holes in the inner fenders, however. (I have since removed my inner fenders, and it makes working on the car much easier)
