I know. It’s an M body but. Issues. Help.
Mopar General Discussions
  1. 71_dart_swinger
    71_dart_swinger Well-Known Member
    293
    98
    Apr 6, 2007
    central valley cali
    Local Time:
    7:36 AM
    So I know it’s not an abody. But this is my go too lol. Taking the lean burn off of my 86 fit have. I’ve put on a brand new 2bbl none electric control ditched the distributor and put in a Chrysler electronic ignition and vacuum adv distributor. It fired right up. Ran for 20-30 seconds like before. Then died. The lines the the smog canister are just plugged on the carb Just to get it started. New cap. Rotor. Plugs. Fuel pump. It’s like something is just shutting it off. Then hard start. Usually won’t start. Any suggestions.
  2. Bodyperson
    Bodyperson Pedal to the metal FABO Gold Member
    6,338
    8937
    Nov 26, 2015
    NW MONTANA
    Local Time:
    8:36 AM
    You running a ballast resistor?
    • Like Like x 1
    • 71_dart_swinger
      293
      98
      Apr 6, 2007
      central valley cali
      Local Time:
      7:36 AM
      Yes and no. I ran it with and without just the ballast. I have an internal coil. And same thing
    • 408 swinger
      408 swinger FABO Gold Member FABO Gold Member
      2,397
      2229
      Nov 12, 2010
      Iowa
      Local Time:
      9:36 AM
      Where are you getting power from to supply the ECU? Souns like you're on a timed relay wire.
    • 71_dart_swinger
      293
      98
      Apr 6, 2007
      central valley cali
      Local Time:
      7:36 AM
      Right off the back of alternator
    • superchargeddrt
      superchargeddrt Well-Known Member
      2,366
      926
      Aug 24, 2009
      Pittsburgh, Pa.
      Local Time:
      10:36 AM
      Pickup coil in the distributor? Remove the coil wire from the distributor, stick a screwdriver into it and place it near ground. Unplug the 2 pin connector at the distributor and short across the wires (not the wires going into the distributor but the other end of the connector) and you should get a spark from the coil everytime you lift the wires from the connector.. if you do then there's something wrong with the distributor (probably the pickup coil). Hopefully this will help you.
      • Like Like x 1
      • 71_dart_swinger
        293
        98
        Apr 6, 2007
        central valley cali
        Local Time:
        7:36 AM
        It’s a brand new mopar electronic ignition. Literally brand new distributor new cap new rotor. Brand new orange box. Brand new carb. It fired right up after doing ignition.
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
        20,958
        8293
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        9:36 AM
        If it ran for 20 or 30 seconds, my guess is the fuel bowl ran dry. Yur first test should be a fuel delivery test; or pop the top and look; or simply pour about 50cc of fresh gas into the bowl thru the bowl-vent, then retest. Speaking of bowl vents, the bowl has to be vented to atmosphere so it can get in there and push the fuel up the fuel wells. Did you, by any chance cap yours?, lol.
        • Thanks! Thanks! x 1
        • 71_dart_swinger
          293
          98
          Apr 6, 2007
          central valley cali
          Local Time:
          7:36 AM
          Lol. Yes it is vented to atmosphere. It’s driving me crazy
          Also took fuel door off. Just in case the tank vent is plugged. But same.
