My 340 Demon has been sitting in my unheated garage for the last 2 months. I decided today would be a good day to start it and let it run for a while. It is -4C and snowing here today. Anyway, I opened the main garage door and then got in the Demon. Without touching the gas pedal I turned the key to the run position to let the fuel pump pressurize the fuel system and then turned the key the rest of the way to start. The engine rolled over about 5 turns and fired right up. It idled a little rough for a couple of seconds and then smoothed out to a high idle. Now keep in mind that this is a 6-71 GM blower car and it takes a little longer for the mixture to get to the cylinders and that is why it rolled over 5 turns. I could never get this car to start like this with carbs. It was always a struggle to start in cold temperatures and would take 5 minutes of playing with the throttle before it would idle. All I can say is the Fitech EFI is great for me.
Jack
Jack
