I need a 360 flywheel and clutch
res1vw21
It's only metal
Renton Wa
I need a 360 flywheel and clutch. I could do with just the flywheel but I need something to put behind a motor to make it so I can move a car around, and maybe drive it a little.
Thanks -Ross-
Also I am looking for a '67-'69 floor shift steering column.
what year 360 do you need a fly wheel for ?? it makes a difference,,,71 thru 91 i believe are all the same,then the magnum series 360,s or 5.9 flywheels are different
