[WANTED] I need heater delete plate!?!?
pilotsf
Rating - 0%
0   0   0
Hi guys. You have not let me down in the past. I need a heater delet plate for 68/69 dodge dart and maybe even the heater core plate that goes in engine bay hole :). Trying to go old school hemi. Plus I can't find a heater switch anyway. Lol. Thank You !
Most guys seem to make theres. Unless your going for a certain look. I took my stock one that went around the blower motor and welded in a piece of metal to cover the hole and painted it.
Use the blower motor plate outside geometry as a tracing to make a delete plate out of flat sheet metel. Use the same hole spacing. Paint it semi flat black. Should look just like original... Done.
I need the dash heater delete bezel too. I've seen them around. But of course not when I need one. Ideas.
Thank you btw. :)
Posted via Topify using iPhone/iPad
I need the dash heater delete bezel. Any ideas. ?
I've ripped out the heater core just now. I'm committed. Lol
Go to a plastics store and see if they have some plastic sheet that is textured on one side. Cut square to fit in the recess.
Fill in the radio hole with plastic squares, super glue, then bondo smooth.
Paint all with SEM Laundau Black.
Wow. That looks amazing. Thsnks for the great idea. Will doo !
Like these?
They're from a 68 Valiant.
Some one hacked out my dash to put an aftermarket radio in. Did not think I could save it so I used some scrap plastic to make a delete plate.
