I need suspension EXPERT opinion
Suspension, Steering and Chassis
  1. challenger57
    challenger57 cuda57
    207
    15
    Sep 21, 2007
    york, pa.
    Local Time:
    1:21 PM
    Here is my build. I have a 63 valiant pro street with an Alterkation front end, a 400 big block and 7 qrt oil pan, coil over shocks with 450 springs. My problem is inorder to get my oil pan off the floor 3 plus inches I have to crank up on the springs making my front SOOO hard there is no rebound on the springs. It feels like I have solid rods instead of shocks. The shocks are 14 inch when fully extended. Currently they sit at 12.5 inch and info says fully compressed are 10 1/8 giving me 2 3/8 of travel. I do not have tunnel clearance to try and raise the motor mounts. There is not enough travel between the upper and lower control arms for longer shocks. I am waiting for a response from RMS on what they suggest. Any thoughts???
    • Like Like x 1
    • abodyjoe
      abodyjoe Well-Known Member
      21,177
      6645
      May 22, 2004
      Berlin,N.J. 08009
      Local Time:
      2:21 PM
      best bet is to listen to what bill tells you....
      just a note. bill has been short handed so answering calls has lacked some.. think his help is back from vacation now so you should be good..
    • roccodart440
      roccodart440 Well-Known Member
      5,720
      4713
      Apr 19, 2010
      Local Time:
      2:21 PM
      Did you call or email?
      My experience is you are much better off calling.
    • challenger57
      challenger57 cuda57
      207
      15
      Sep 21, 2007
      york, pa.
      Local Time:
      1:21 PM
      I got to talk to Bill today and we discussed what i have. My ride height is set good with the springs. I currently have 24" skinnys up front and he tells me that the set up is engineered for 26" tires, that would give me an extra inch in clearance. Once I get this thing on the road I will have to play with the damper adjustments. He said the ride will not be as stiff as it feels sitting still once moving.
    • moparlover
      moparlover Well-Known Member
      2,628
      25
      Dec 17, 2011
      hagerstown, md
      Local Time:
      2:21 PM
      also there are more than one type of 7qt oilpan. there is a low profile and a deep sump
      they take different pickups, so you cant just swap the pan
