[WANTED] I want to buy A-body reinforced lower control arms with sway bar tabs
ED'S68CUDA
Ed in SoCal
Southern California
Rating - 0%
0   0   0
I will put the 1973-76 front Disk brake factory set up on my 1967 Barracuda. Want to buy and use tubular UCAs, reinforced LCAs, and custom small bolt pattern disks instead of factory OR large bolt pattern 8.75 rear axle shafts. Want to buy the prop valve and brake master with or without booster - what do you recommend? I live in Southern California.
