I wonder if...
Woods74
Broke Senior
Seattle, WA
http://www.jegs.com/i/Mopar-Performance/312/P5007790/10002/-1?parentProductId=
http://www.summitracing.com/parts/fst-302000
:toothy1:
nice concept,send Magnumdust a p.m.. He tried the Professional Products setup.
The factory OBDII stuff works great when properly set-up and reflashed with the right tune. I'll let you know just how good in another month or so.
I did the PP powerjection 3 and it is by far the best thing i've put on the car, but i think the OP is thinking of using Magnum style efi controlled by ez efi.
JMO: Great idea in theory, but the magnum throttle body has cfm limitations. Also the ez efi itself is a limited efi system. NA only, no real tuning options other than the self tune.
The money you'll spend to get that together will be equal to or greater than the holley avenger equivalent and you'll get all the ez efi benefits and none of the drawbacks.
