Scottieg85
New Member
Hey guys, I have a question pertaining to the ECU/Ignition box. I have a 440 which had an MSD system but was “upgraded” to an edelbrock EFI system. I was tearing out the MSD system today because the wire mess was driving me crazy. As I was going through the harnesses I came to a wire going from the ballast resistor (left side) to the ignition box/ECU. This was the only wire that was connected to anything from it, the rest of the wires were disconnected or dead ended. I unplugged the plug from the ECU and the car still started (other than the battery being dead and needing a jump, she started right up and seems to run fine. Is there any need to the ECU with the EFI hooked up? Thanks in advance!
