Ignition Coil Capacitor Part Number
scatpackbee
Georgetown, Ontario
Does anyone know the ignition coil capacitor part number for (radio noise suppression) for a 1969 Dart with a 340.
I have searched the 1969 Mopar Parts book from front to back and could not locate it in the book.
If you have a picture of one that would help too.
Thanks
Excluding the attaching bracket it's just a standard condensor like a points ignition system used.
The wire attaches to the coil + side, and the body of the unit is grounded to the coil bracket via the attaching point.
If you are looking for the factory correct peice, the bracket that attaches it to the coil mount is what matters.
I was looking at some upclose pictures I had taken at the VerHage Mopar museum and I can see part number 2107674 stamped at the end of a capacitor on a 1968 Barracuda 318 but when I checked the '68, 69, 70 and 71 Mopar parts book part number index, this part number does not exist.
Anyone have any info?
I will try to post the picture of the capacitor.
It sounds like you are going for "period correct". Otherwise, those are fairly generic and used to be found in the Help bubble packs in auto parts. Worst-case you get one for a Ford or such w/ a different terminal you cut off and add a ring terminal.
