Ignition Points?
DukeTheDuster
Duke The Duster
Tennessee
Does the 1974 Duster SL6 have ignition points? Ibe has this car for a while but I can’t seem to find a replacement for them! Thanks
.............That doesn't mean someone didn't yank it out of there and stick a breaker point distro in instead. By the way, l Mopar (aluminum distro) used the same points, over the years, "period." Dual points distro were a different matter
Ah ok thank you, that explains a lot!
The only adjustment to check is to use a .007" or .008" brass feeler gauge to check the gap between the reluctor ribs and the pick-up..
Then put a good cap and rotor on and the distributor is good to go...
Pop off the distributor cap and look. If you see a toothed ring w/ magnetic pickup, yours is stock. For a little hotter spark, you can change the factory ECU to a GM 8-pin HEI module. It works with your pickup. Many posts.
