[SOLD] ignition switch bezel nut
bbrroowwnn
never re member
Drums, PA
looking for an ignition switch bezel nut for dash mount switch....It is for a 1960-1968 mopar switch but must be a flat nut style with the threads going right to the end...cannot have any taper on the back with threads inset...... 7/8 inch opening and about 1/4 inch deep or so....pm me if you have one
I have quite a few too if you have trouble finding the correct one.
Thanks, Mark
I have one on the way from Vdart.....looks right....wont know until it gets here...I will let you know
I got it today Vdart ....that is the style I needed, unfortunately it is too big in diameter so it won't thread on.....The opening was 15/16 and I need 7/8.....So I am still looking for one ASAP if any other members have one for sale...thanks
I didn't realize there were different diameters.....I Pm'ed barracudakid and cudamark to see what you have
The switch I need the nut for is part number 2497158 which replaces 1887394 and 2097628.....the ebay item # of the switch I purchase in case you want to look at pics is 370382980816...thanks
I have 2 switches with bezels, casting #'s 2864259 short style, I believe is 68 and for all models...the other casting # is 2864464, long style I believe is 69 for all models with retainer #2947005...dunno if it helps, sorry it doesnt look like I have one.
I found 4 that I have, I will post the pics here for you to look at them, I think 3 are 65-66 a-body and one is a larger diameter for a 66 b-body, only one has a part number on it, it is 2631549. Pics will be up later, have to run now :glasses7:
Yeah, from what I am hearing the 60-68 switches have the 7/8 diameter threads, that is what I need....must be flat in the back to fit flat against a sheet metal dash.....the front hole diameter of the bezel must be 13/16 or 7/8 but no bigger or no smaller.....And the hole must be centered in the bezel , not offset....If anybody has one fitting this description I would like to see a pic...thanks
Here you go, will any of these work?
The two in the back definitely wont work....the 2 in the front may....what is the thread diameter of the each of the two in the front? 7/8 or 15/16?
thanks for checking!
Here are some of the ones I have.......
The second one from the left in top row, what is the diameter of the hole in the front of it? 13/16 or 7/8 would do me....Also the threads have to be 7/8 but I think you said everything pictured was the 7/8 thread......if that one doesn't pan out the one in the top row on the left and bottom row on the left would be my next choices.....
All the bezels shown thread on the ignition switch in the photo. I'll get some close-ups of those three you mentioned.
