This will be a dumb question to the electrical wizards on here, but here goes. When making electrical tests where the ignition needs to be in the "Run" position, does the engine have to be running? Or can you just move the key to the "Run" position?
Depends what you are testing.This will be a dumb question to the electrical wizards on here, but here goes. When making electrical tests where the ignition needs to be in the "Run" position, does the engine have to be running? Or can you just move the key to the "Run" position?
