hippy 60
I have a 63 Valiant and was hooking up the wires enough to see if it would crank,I plugged in the switch with the big plug and it has another termnial on it i was wondering which wire goes there it will click using the switch but won't turn the motor over ,But you can jump the starter relay and it will crank.What is wrong with it.??????? Thanks for any help.
