The car is a 1968 Dart, one of the previous owners did some fancy wiring and now you need to flip a switch to get power to the vehicle.
I want to be able to turn the key to the run position and have power and not have a separate switch. The car still cranks with the key once the "accessory" switch is flipped. The car will not turn off unless the key and switch are off however.
It looks like the accessory switch is connecting a hot (directly from the battery +) and the black wire that should have gone to the alternator indicator (it no longer does). The red wire that should be going to the alternator indicator and then to the accessory breaker is taped off.
If I hook the red and black back up to the alternator indicator, where does the red one go to get to the accessory circuit breaker? I couldn't find it anywhere. And do you think this will solve my issue? If not, is there another safe way to get this working right again?
Thanks!! I know this is a lot to read for one question.
