Brian Hafliger
Hi guys. Just wanted to let you guys know we WILL be follwing up our first article in CC with a second article using the same bottom end as before.
This time I'll be porting a set of eddy heads, using a roller cam of some type either hyd. roller or solid roller.
It will be pump gas friendly, still somewhat cost effective and after we've tested a few things with carbs we will be running it with EFI. We also plan on trying F&B's 3-2BBL injection setup.
I'm running the 410 one more time this upcoming week to see if the 3/8 pushrods and pushrod oiling had any affect on the engine, plus will be testing the electric water pump, and a 950HP carb in place of the 750DP.
I'll post the results of the test.
Brian
Brian
