[WANTED] In need of a small block crankshaft pulley
younggun86
Member
atlanta georgia
Rating - 0%
0   0   0
I have a 1968 318 and i want to convert my original 3 belt pulley to a double pulley because i put an aluminum radiator in and my fan wont clear the pulley. Do anyone know where i can get a double crankshaft pulley from. i just wana drive my lil 318 fb cuda until i get enough money to build and stroke my 340. Any info would highly be appreciated Thanks
I am pretty sure Mancini sells them.
Keep in mind there is a different bolt pattern on early and late LA.
wouldn't it make more sense to find a smaller fan spacer?
do you still have the A/C set-up?
take a measurement and let me know if you think a 1 inch fan spacer will do the trick for you, I think I have one laying around from a slant 6 which should work for you
(just reread your post, the fan is hitting the pulley? or the radiator?)
I guess I don't see how it could be hitting the pulley unless someone already installed a smaller spacer?
you don't have any pictures do you ?
(almost sounds like the harmonic balancer isn't installed properly)
this is how far the snout of my waterpump sticks out past my 3 groove pulley
I got a 360 mag 1998 come haul truck away after you see it run 1200.00 Somebodies got 1 laying around , ifnot pm mei will pm you a junkyard that will have 1 or 300
