In the meantime...
TheGrateRonzini
Western New York
So, I got my hood from Kramer a few weeks ago, couldnt be happier with it. Totally worth the tag. Also buttoned up the bottom end, clearanced the pickup and all that fun stuff. Hoping to get it all together before the summer, or after the havoc anyhow.
Any suggestions on pulling the inner springs for break in? Hyd roller/TF240/harland. Consensus is No. I was told with the roller lifters to disregard the notion. Just wondering what you all do. I have the C clamp compressor, and the dinky overhead one that never works. I can make a shaft style one if need be. I certainly dont want to use a spare set of felpro head gaskets just to pull the heads to replace the springs and replace with the cometics. Thanks
I did mine with shaft style and compressed air in cylinder. That was flat tappet not roller. Roller I don't know if necessary .
