Indy 245cnc heads & intake for sale
Brian Hafliger
SoCal
Rating - 0%
0   0   0
Selling Indy CNC ported SB heads. 245 intake port, hand ported exhaust ports and chambers, 5/16 stems, 2.100x1.60 or I have 2.15 intakes I can install. They flow 340cfm at .700 lift and the chambers are 53cc. They have been angle milled 1/2 a degree.
Also have Jesel 1.7 and 1.6 intake and 1.6 exhaust rocker setup...dyno time only for heads and rockers.
I'm selling the heads with valves and rockers for $3250.00 or 3400.00 with new 2.15 valves installed with new valve job on intake.
I have spring kits available if needed for whatever the application.
Also for sale: Indy rect. port intake, ported plenum and runners and machined for injectors (can be plugged). I can sell it with injectors and rails $700 or without $475.00.
Brian
