Indy crossram throttle linkage
pearlblue
Active Member
in the hills
I'm fabricating a linkage for twin holleys on a Indy crossram intake. I got everything in place, but the linkage on the front carb interfers with the arm on the carb past 3/4 throttle. I'm trying to maintain parallel geometry with the linkages to ensure equal travel. Also, the arms on the carb go over center at wot. I'm thinking of making an add on to the carburater arm to fix the clearance problem, and start the travel of the throttle at a different angle to prevent the over center of the linkage. Does anyone have any experience with this or have any suggestions? I looked at pictures of SS/AH linkages and it looks like the arms were bent to fix this, but again everything must be identical to have equal travel.
