Indy Cylinder Heads
dylan_becker
Member
minnesota
I'm building a 360 motor and am wondering if anyone has any suggestions on a new set of cylinder heads. I want this car to be a good daily driver, nothing too aggressive. Indy Cylinder Heads makes a LAX head that is supposed to be close to as good of flow as an edelbrock aluminum head at a much nicer price. Has anyone had any experience with these heads, or do you know of any other good aftermarket heads? Thanks. Any info is very helpful.
RHS heads flow exceptionally well. They are cast iron though (nothing wrong with that I just prefer aluminum, so I went eddy closed chamber heads for my 340. Part of the reason was I stuffed a hyd roller cam in the block), I believe member OU812 (pretty sure that's right) can sell them to you and port them.
X2 thats Brian @IMM engines, OU812, he built a RHS headed stroker, it was in Car Craft mag a few months ago, he will be happy to sell you ready to bolt on heads.
