indy heads under a stock hood
h340
pennsylvania
is it possible to fit a small block with indy heads and intake under a stock dart hood with an air cleaner, if not can the intake be milled down and how much.??
thank you krumenacker
Heads are not the problem, the hieght of the intake could be.
Figure out how much room is under the hood now and combine that measurement with the total height of the air cleaner/intake and carb.
then find out how tall the indy intake is and add it up with the proposed carb and cleaner.
