67Dart273
!!HUH!! Old man learned something. Was into the Dodge ram service manual and saw a little drawing about inline splice "clips" A simple little "U" shaped clip that you wrap around the "running" wire along with the "to be added" tap wire, and crimp. Solder........Makes a nice compact splice.
Mopar Connection Repair Kit
Part no's for the clips:
TSB 08-06-00
- Remove 13 millimeters (0.50 inch) of insulation from each wire that needs to be spliced.
- Place a piece of adhesive sealant-lined heat shrink tubing (Part Number 04778570 or equivalent) over the wire on one side of the splice. Be certain the length of tubing will be sufficient to cover and seal the entire repair area.
- Place the strands of the wires being spliced so that they are overlapping each other within the splice band (1).
- Using a crimping tool (1) (MOPAR Part Number 05019912AA, Miller Special Tool Number 10042 or equivalent) crimp the splice band and wires together securely.
- Using rosin core type solder (1) only and a suitable solder- ing iron (3), solder the wire and splice band connection (2) together.
- Center the heat shrink tubing (2) over the splice joint repair and heat using a suitable heat gun. Heat the joint until the tubing is tightly sealed and sealant (1) begins to ooze out of both ends of the tubing.
TSB 08-06-00
