Input Shaft Grease?
srduster340
Decatur,Ga.
Should I put any grease on my input shaft splines before I install it?
I would not. I WOULD however grease the pilot bushing cavity.
1970 factory service manual says don't lube the splines. I have on occasion seen the clutch disc "seized" to the trany input splines; a slight amount of wheel brg grease wiped across the trany shaft splines prevented the problem from reoccuring.... but FABO members probably don't drive their rigs in harsh environments.
