Its not about what it looks like,.
I've been around electronics for a very long time and I say.QUOTE]
As have I and this is pretty common.
You can't see well enough to make any
assessment of the quality of the components.
The soldering looks like it might have been done
by hand which is not uncommon either.
If you believe its a cold solder joint, resolder
and try it again.
As for total quality you'd have to make that accessment
for yourself and act accordingly.
Your other choice is a single chip like the HEI which
in my opinion is hard to beat.
You could buy the MSD and see whats in their box.
If you like you can google it or I can do it for you.ottytra:
I just finished gutting an old one I replaced that was intermittant bad.damn wish i had an orange box to compare....
Mine is/was the same way, One interesting point is where there is the large gob that grounds the board to the case seemed it was a cold joint, probably causing my intermittant problem?Quick put some black goop back over it, it is making me sick .
The gobs of solder are horrible. I think there are loose solder balls near the top.
I've been around electronics for a very long time and I say...............
So you can have the huge piles of cold solder if you want, that's OK............
That photo of the MSD box with the in-distributor ignition module is hilarious. Did an owner do that, or was that a clever Chinese copycat solution?
That looks like an unsuspecting Standard Ignition LX101.
Just to put things in more modern perspective, this is what I would use, no external ballast required.
Included:
chip for Variable Reluctance trigger (actually for 2 triggers)
IGBT ignition driver
Automotive rated voltage regulator for 5V
Current limit control
Misc. caps and resistors
I am more into Hall and Optical than VR, so no plans to make a kit.
Size reference.
Thats a Pertronix unit that someone installed inside the box so it looked factory.
I have already built two 4 pin HEI factory boxes like this so far.
I know, I was messin with ya.
I was going to say that a copper plate would look a lot more professional than a penny for a heatsink.
